[Docker] Update Fehler
Verfasst: Mi 2. Feb 2022, 16:29
von cookie
ich versuche seit heute mein homeassistant docker container auf den neuesten stand zu bringen
leider haut das über das "ei23" menü und "komplettes update" nicht hin.
jedes mal kommt folgender fehler:
                .,:cc:'
             .ckXWMMMMNd.
           .c0WMMMMMMMNd.  ..
          'kWMMMWXOxol,   'kk'
         ;KMMNkl,.    ..:xXMMK;
        :XMMK;   .;ldx0NWMMMMMX:
       ;KMMNc  .xXWMMMMMMMMMMMMK;
      .OMMMX;  .,;;;;;;;;;;dNMMMO.
      lWMMMNo''..........'.lNMMMWl
     .OMMMMMWNNNNNNNNNNNNNNWMMMMMO.
     ;XMMMMMMMWX0kxxxxk0NWMMMMMMMX;
     :NMMMMMWOc.       ..cOWMMMMMN:
     ,KMMMMMk.  'lxxxxl.  .kMMMMMK,
     .xMMMMWOoldKMMMMMMx.  lWMMMMx.
      '0MMMMMMMMWKOOOOd' .:0MMMM0'
       'OWMMMMMMX: .     ;OWMMWO'
        .oXMMMMMW0kkkkd:. .oXXo.
          .l0NMMMMMMMMMN:  .,'
             'cdkO0000Ol.
//// update... (das kann eine Weile dauern)
ei23.sh: line 205: pip3: command not found
ei23.sh: line 206: pip3: command not found
sudo: pip3: command not found
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package python-rpi.gpio is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'python-rpi.gpio' has no installation candidate
WARNING: Some networks were defined but are not used by any service: nextcloud, fireflyiii
Pulling mosquitto     ... done
Pulling ei23          ... done
Pulling influxdb      ... done
Pulling bitwarden     ... done
Pulling esphome       ... done
Pulling grafana       ... done
Pulling homeassistant ... done
Pulling motioneye     ... done
Pulling pihole        ... done
Pulling portainer     ... done
Pulling traefik       ... done
Pulling vscode        ... done
Pulling zigbee2mqtt   ... done
WARNING: Some networks were defined but are not used by any service: fireflyiii, nextcloud
Recreating 87f8bd03eda7_pihole ...
vscode is up-to-date
zigbee2mqtt is up-to-date
Recreating 49dc5dc2f15a_homeassistant ...
Recreating b7530311b240_mosquitto     ...
Recreating 3861a901a109_influxdb      ...
traefik is up-to-date
Recreating 87f8bd03eda7_pihole        ... error
esphome is up-to-date
Recreating 2c29591fd857_bitwarden     ...
motioneye is up-to-date
Recreating b7530311b240_mosquitto     ... error
Recreating 49dc5dc2f15a_homeassistant ... error
ERROR: for 87f8bd03eda7_pihole  Cannot create container for service pihole: unknown log opt 'max-size' for journald log driver
ERROR: for b7530311b240_mosquitto  Cannot create container for service mosquitto: unknown log opt 'max-size' for journald log driver
Recreating 3861a901a109_influxdb      ... error
ERROR: for 49dc5dc2f15a_homeassistant  Cannot create container for service homeassistant: unknown log opt 'max-file' for journald log driver
Recreating 2c29591fd857_bitwarden     ... error
ERROR: for 2c29591fd857_bitwarden  Cannot create container for service bitwarden: unknown log opt 'max-size' for journald log driver
ERROR: for pihole  Cannot create container for service pihole: unknown log opt 'max-size' for journald log driver
ERROR: for mosquitto  Cannot create container for service mosquitto: unknown log opt 'max-size' for journald log driver
ERROR: for homeassistant  Cannot create container for service homeassistant: unknown log opt 'max-file' for journald log driver
ERROR: for influxdb  Cannot create container for service influxdb: unknown log opt 'max-size' for journald log driver
ERROR: for bitwarden  Cannot create container for service bitwarden: unknown log opt 'max-size' for journald log driver
ERROR: Encountered errors while bringing up the project.
alle container laufen, außer influx und home assistant.
hat jemand eine idee?
gruß
Re: [Docker] Update Fehler
Verfasst: So 6. Feb 2022, 14:22
Ich sehe da was von Python, pip3 und GPIO. Kommt mir verdächtig vor.
Bring mal dein Python manuell auf den neuesten Stand und update dann nochmal.
Und dann sehe ich da noch probleme beim logger.
Prüf mal deine docker-compose.yml
So sollte das eigentlich aussehen, kannst den Teil aber auch ganz rausnehmen.
Normal sollte das aber gehen... Aber erstmal um Python kümmern, vielleicht erledigt es das schon
