Server nach einigen Stunden nicht mehr erreichbar
cookie
Beitrag von cookie »
ich habe ein Problem. Leider ist der Server nach ca. 4-5 Stunden nicht mehr erreichbar über das Netzwerk. Auch arbeiten keine Automatisierungen mehr über Home-Assistant.
Hier ein auszug aus dem Syslog
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: bits received from HRNG source: 160064
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: bits sent to kernel pool: 120000
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: entropy added to kernel pool: 120000
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: FIPS 140-2 successes: 8
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: FIPS 140-2 failures: 0
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: HRNG source speed: (min=130.060; avg=330.089; max=547.938)Kibits/s
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: FIPS tests speed: (min=21.169; avg=24.492; max=25.915)Mibits/s
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: Lowest ready-buffers level: 2
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: Entropy starvations: 0
Oct 13 20:29:50 smarthomeserver rngd[468]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 13 20:30:01 smarthomeserver avahi-daemon[395]: Withdrawing address record for 192.168.4.28 on eth0.
Oct 13 20:30:01 smarthomeserver avahi-daemon[395]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.4.28.
Oct 13 20:30:01 smarthomeserver avahi-daemon[395]: Interface eth0.IPv4 no longer relevant for mDNS.
könnt ihr damit etwas anfangen? gruß
cookie
Re: Server nach einigen Stunden nicht mehr erreichbar
Ich habe es hingekriegt, nachdem ich einige container, u.a. die influxdb gestoppt habe...
solang die nicht laufen scheint alles i.o. zu sein.
Zumindest für ca. 4,5 bis 5 Tage.
Danach ist nur noch Home Assistant erreichbar. Die anderen container laufen nicht mehr.
Außerdem ist kein Zugriff per SSH mehr möglich und die Startseite läuft nicht mehr.
Lediglich eine Fehlermeldung von nginx ist zu sehen.
Startet ihr euren pi alle paar tage über z.b. einen cronjob neu?
ab und an habe ich probleme, dass der pi nicht richtig bootet. Er bleibt im bootvorgang hängen. Liegt im Zusammenspiel mit der SSD. Hab schon 2-3 andere usb zu ssd controller ausprobiert.
Mit der SD karte hatte ich nie probleme... bin am überlegen diese zum booten zu nutzen.
Hat jemand ähnliche Erfahrungen gemacht?
Ich hatte schon viele Probleme, aber grundsätzlich kann und sollte es auch reibungslos ohne Neustarts laufen.
Sollte man zumindest anstreben.
Aber wenn der Pi beispielsweise keine Verbindung zum Router haben sollte, starte ich den auch automatisch neu.
Wenn SSH nicht mehr geht, ist meistens ein Zeichen dafür, dass er komplett hängt. Ich hab daher auch LED am Pi, die mir den Status direkt anzeigen
Ich hatte mal ein Relais für eine Sprinkleranlage am Pi, die hat für so ähnliche Probleme gesorgt.
Aber da half dann auch kein Neustart über Cronjobs mehr.
Der Pi4 ist gegenüber den Pi3 etwas empfindlicher an de GPIOs habe ich das Gefühl.
Vieles lässt sich aber gut aus den Logs in Portainer / Docker auslesen.
In jedem Fall sind die Probleme immer recht individuell.
Je nach dem was für Soft- und Hardware man so ge- und verbaut hat.
