[Docker] VSCode
pekabo
[Docker] VSCode
Beitrag von pekabo »
Hallo @ all,
nach dem Update funktioniert fast alles, sobald ich versuche, den VSCode-Editor aufzurufen, erhalte ich im Firefox folgende Fehlermeldungen:
Error: Verbindung fehlgeschlagen
Firefox kann sich nicht mit dem Server unter xx.xx.xx.xx:2222 verbinden...
Ein Neustart des conatiners vscode in Portainer für führt nicht zum Ziel. Ich verwende kein Passwort in der docker-compose.yml für vscode.
Folgenden Fehler erhalte ich im VSCode Log vom Portainer:
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 01-envfile: executing...
[cont-init.d] 01-envfile: exited 0.
[cont-init.d] 01-migrations: executing...
[migrations] started
[migrations] no migrations found
[cont-init.d] 01-migrations: exited 0.
[cont-init.d] 02-tamper-check: executing...
[cont-init.d] 02-tamper-check: exited 0.
[cont-init.d] 10-adduser: executing...
usermod: no changes
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
Brought to you by linuxserver.io
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User uid:    0
User gid:    0
Your DockerHost is running an outdated version of libseccomp
To fix this, please visit https://docs.linuxserver.io/faq#libseccomp
Apps will not behave correctly without this
sleep: cannot read realtime clock: Operation not permitted
[cont-init.d] 10-adduser: exited 0.
[cont-init.d] 30-config: executing...
setting permissions::configuration
setting permissions::workspace
[cont-init.d] 30-config: exited 0.
[cont-init.d] 90-custom-folders: executing...
[cont-init.d] 90-custom-folders: exited 0.
[cont-init.d] 99-custom-scripts: executing...
[custom-init] no custom files found exiting...
[cont-init.d] 99-custom-scripts: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
starting with no password
Node.js[376]: ../src/util.cc:188:double node::GetCurrentTimeInMicroseconds(): Assertion `(0) == (uv_gettimeofday(&tv))' failed.
Habt ihr einen Tipp wie ich das behebn kann?
Pekabo
Re: [Docker] VSCode
Tut mir leid, leider nein.
Ich habe auch überlegt upzudaten, habs dann aber gelassen - gute Entscheidung :lol:
Hast vorher ein Backup gemacht auf das zu zurücksetzen kannst?
Bzw. wenn du das Problem gelöst hast, wäre es toll zu wissen wie :D - danke.
Re: [Docker] VSCode
Na steht hier nicht die Lösung des Problems ?
Da führt es einen dann zu
https://docs.docker.com/engine/install/debian/
pekabo
Re: [Docker] VSCode
Andy hat geschrieben:
Mo 31. Jan 2022, 21:54
@Andy Danke, das war der Richtige ansatz.
Ich habe libseccomp auf dem OS Raspbian GNU/Linux 10 (buster) aktualisiert.
Die Paketadresse im wget-Befehl sind nicht mehr aktuell. Ihr könnt die neuesten Versionen hier finden.
Für mich war die richtige Lösung (Stand 01.02.2022)
wget http://ftp.us.debian.org/debian/pool/main/libs/libseccomp/libseccomp2_2.5.3-2_armhf.deb        libseccomp2_2.5.3-2_armhf.deb
sudo dpkg -i libseccomp2_2.5.3-2_armhf.deb
VSCode läuft wieder und alles ist UpToDate (Komplettes Update)
Re: [Docker] VSCode
Merke:
In Zukunft immer die komplette Fehlermeldung lesen ! :mrgreen:
Re: [Docker] VSCode
So lernt man doch immer was dazu 8-)
