ich habe über docker-compose.yml den IOBROKER installiert.
Laut Status läuft der Container auch, allerdings bekomme ich keine Verbindung über Port 8081.
Im syslog findet sich:
Aug 3 22:05:28 raspberrypi systemd[1]: Started ioBroker Server.
Aug 3 22:05:28 raspberrypi bash[11382]: node:internal/modules/cjs/loader:1080
Aug 3 22:05:28 raspberrypi bash[11382]: throw err;
Aug 3 22:05:28 raspberrypi bash[11382]: ^
Aug 3 22:05:28 raspberrypi bash[11382]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/controller.js'
Aug 3 22:05:28 raspberrypi bash[11382]: at Module._resolveFilename (node:internal/modules/cjs/loader15)
Aug 3 22:05:28 raspberrypi bash[11382]: at Module._load (node:internal/modules/cjs/loader:922:27)
Aug 3 22:05:28 raspberrypi bash[11382]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
Aug 3 22:05:28 raspberrypi bash[11382]: at node:internal/main/run_main_module:23:47 {
Aug 3 22:05:28 raspberrypi bash[11382]: code: 'MODULE_NOT_FOUND',
Aug 3 22:05:28 raspberrypi bash[11382]: requireStack: []
Aug 3 22:05:28 raspberrypi bash[11382]: }
Aug 3 22:05:28 raspberrypi bash[11382]: Node.js v18.17.0
Aug 3 22:05:28 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
Aug 3 22:05:28 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
Aug 3 22:05:31 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
Aug 3 22:05:31 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 9153.
Aug 3 22:05:31 raspberrypi systemd[1]: Stopped ioBroker Server.
Aug 3 22:05:31 raspberrypi systemd[1]: Started ioBroker Server.
Aug 3 22:05:32 raspberrypi vncserver-x11[483,root]: AgentInitCheck: no response from agent
Aug 3 22:05:32 raspberrypi bash[11390]: node:internal/modules/cjs/loader:1080
Aug 3 22:05:32 raspberrypi bash[11390]: throw err;
Aug 3 22:05:32 raspberrypi bash[11390]: ^
Aug 3 22:05:32 raspberrypi bash[11390]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/controller.js'
Aug 3 22:05:32 raspberrypi bash[11390]: at Module._resolveFilename (node:internal/modules/cjs/loader15)
Aug 3 22:05:32 raspberrypi bash[11390]: at Module._load (node:internal/modules/cjs/loader:922:27)
Aug 3 22:05:32 raspberrypi bash[11390]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
Aug 3 22:05:32 raspberrypi bash[11390]: at node:internal/main/run_main_module:23:47 {
Aug 3 22:05:32 raspberrypi bash[11390]: code: 'MODULE_NOT_FOUND',
Aug 3 22:05:32 raspberrypi bash[11390]: requireStack: []
Aug 3 22:05:32 raspberrypi bash[11390]: }
Aug 3 22:05:32 raspberrypi bash[11390]: Node.js v18.17.0
Aug 3 22:05:32 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
Aug 3 22:05:32 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
Und da hat er Recht: das Verzeichnis /opt/iobroker gibt es nicht (mehr). Hatte ich vielleicht mal vor ei23 dort installiert...
Danke vorab!
