Ich habe mir für meinen Dreame L10s Ultra über HACS eine Integration geladen. Diese läuft soweit auch, allerdings lädt er nicht die erstellte Karte runter. Hier mal ein Auszug aus dem Log.
Dieser Fehler wurde von einer benutzerdefinierten Integration verursacht
Logger: custom_components.dreame_vacuum.dreame.map
Source: custom_components/dreame_vacuum/dreame/map.py:468
Integration: Dreame Vacuum (documentation, issues)
First occurred: 13:48:35 (1966 occurrences)
Last logged: 22:32:41
Request map data from cloud failed https://awsde0.fds.api.xiaomi.com/dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/1?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194082710&Signature=JIqGLcBo82ZAVgLmc5lhZGruOWw=
Request map data from cloud failed https://awsde0.fds.api.xiaomi.com/dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/9?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194098973&Signature=zeR663ihLNU/zHSURRum1s/eyjk=
Request map data from cloud failed https://awsde0.fds.api.xiaomi.com/dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/1?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194114752&Signature=csMp8+3A6Fp0Ef5+Dy/zo/ZB7b0=
Request map data from cloud failed https://awsde0.fds.api.xiaomi.com/dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/9?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194131050&Signature=Tkc4TW73A9rc2A+qlSIqSpBhK/Y=
Request map data from cloud failed https://awsde0.fds.api.xiaomi.com/dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/1?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194146701&Signature=4scpTe/WpxxC4ZJ28QmOGHWezcw=
Logger: custom_components.dreame_vacuum.dreame.protocol
Source: custom_components/dreame_vacuum/dreame/protocol.py:401
First occurred: 13:47:24 (5919 occurrences)
Last logged: 22:33:06
Unable to get file at https://awsde0.fds.api.xiaomi.com/dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/9?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194155999&Signature=hwd4+YC49kHpHamyX6nEt8hpVgc=: HTTPSConnectionPool(host='awsde0.fds.api.xiaomi.com', port=443): Max retries exceeded with url: /dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/9?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194155999&Signature=hwd4+YC49kHpHamyX6nEt8hpVgc= (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7efcd9d97fd0>: Failed to establish a new connection: [Errno -3] Try again'))
Unable to get file at https://awsde0.fds.api.xiaomi.com/dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/9?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194155999&Signature=hwd4+YC49kHpHamyX6nEt8hpVgc=: HTTPSConnectionPool(host='awsde0.fds.api.xiaomi.com', port=443): Max retries exceeded with url: /dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/9?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194155999&Signature=hwd4+YC49kHpHamyX6nEt8hpVgc= (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7efcd5713050>: Failed to establish a new connection: [Errno -3] Try again'))
Unable to get file at https://awsde0.fds.api.xiaomi.com/dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/1?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194171541&Signature=d8+Rz7hDOaPph1u18A+jac44NcY=: HTTPSConnectionPool(host='awsde0.fds.api.xiaomi.com', port=443): Max retries exceeded with url: /dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/1?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194171541&Signature=d8+Rz7hDOaPph1u18A+jac44NcY= (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7efcd5754f10>: Failed to establish a new connection: [Errno -3] Try again'))
Unable to get file at https://awsde0.fds.api.xiaomi.com/dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/1?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194171541&Signature=d8+Rz7hDOaPph1u18A+jac44NcY=: HTTPSConnectionPool(host='awsde0.fds.api.xiaomi.com', port=443): Max retries exceeded with url: /dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/1?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194171541&Signature=d8+Rz7hDOaPph1u18A+jac44NcY= (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7efcda042a90>: Failed to establish a new connection: [Errno -3] Try again'))
Unable to get file at https://awsde0.fds.api.xiaomi.com/dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/1?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194171541&Signature=d8+Rz7hDOaPph1u18A+jac44NcY=: HTTPSConnectionPool(host='awsde0.fds.api.xiaomi.com', port=443): Max retries exceeded with url: /dreame-iot/dreame.vacuum.r2228o/SN038815/661348675/1?GalaxyAccessKeyId=EAKOK5QILPVZ6&Expires=1696194171541&Signature=d8+Rz7hDOaPph1u18A+jac44NcY= (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7efcdbbd9bd0>: Failed to establish a new connection: [Errno -3] Try again'))
Sobald ich diese URLs in meinem Browser eingebe lädt er die Dateien runter.
Daher vermute ich, dass Portainer oder etwas anderes diese URL blockiert. Kann ich diese irgendwie frei geben?
